Scottydoggs
Killa Bee
hey all, new little problem,
after the car is good and warmed up and it seems after a highway run too, when im on local roads going just over 30 mph which is where it locks into 3 rd gear, and im light on the gas, it starts chugging, if i give it gas or let off it stops, but will continue till i get to my desination.
im trying to get a vid of it, it did it a few times when i went out again 30 minutes later but the chugging was softer, not as much rpm fluctuation, (only got it to do it 2 short times) when it does it bad i have 500 rpm range it bounces in, softly the tac hardly moves. but for the most part the last drive it ran fine.
last tune up was a year and half ago but i have only put 5000 miles on it since. used iradium plugs.
im going to go out in a bit to check the plug wires, make sure they are all in the clear.
i did just do a intermediate shaft, and i knocked off a small vac line from the side of the trans, i did find where it went and put it back, it was a vac hose 1 inch long and was capped, it looked like it went where all the plugs for the trans connect on the driver side of the trans. so thats where i put it.
and i do have my old maf still, for all i know its still good because i changed the maf and pig tail at the same time. so i could try to swap that.
thanks for reading.
thanks for reading.
