lewethetiger73
So now that winter is approaching I have noticed the car has little to no heat. It is a 06 GT 3.8 supercharged. I changed the t-stat to a stock temp, replaced water pump, coolant flush and I used gm coolant. After it was all said and done and went for a drive I noticed the engine temp was just below the first line which I thought was pretty low. I was looking it over while it was running I noticed tha a/c compressor was running even with out the switch on. I unplugged the compressor and it got a little warmer but not much. Even with the temp cranked to 90*. The heater core top hose was hot to the touch with the lower one a little cooler but still very warm.
SO any ideas? I was thinking of pulling the heater hoses off and running some water through to see if it was blocked but that will be tomorrow night. Thanks for any ideas you all can give. Thanks
