Check Engine Light
probuilder1
Hey everyone, new here first post hope someone can help. It's a 1999 Grand Prix GT 3.8 and I had the codes pulled and here they are P0449, P0440, P0102, P0141.
P0449 - The PCM has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid.
P0440 - The PCM has determined that a malfunction exists in the evaporative emission control system.
P0102 - The PCM has determined that the mass air flow imput is lower than expected for the current engine operating conditions.
P0141 - The PCM had determined that a malfunction exists in the heater circuit for oxygen sensor 2 in bank 1.
Any info on this would be greatly appreciated.
Your MAF is bad, your EVAP solenoid is bad, and your rear O2 sensor is bad.
Good call. I have a maf that I will sell you if you need one probuilder1 along with an evap solenoid also. PM me if you need them. Thanks
