my build, need opinions
nascartech
ok so i am doing a build next summer and am going to start gathering parts
nic cam,105 springs,new timing chain,42 injectors,and the car already has 180 t stat, 104 plugs sd headers ported blower just want to know what size i should drop to i wanrt to run max timing so i was thinking a 3.0 or a 3.1 then with meth run a 2.8 how does this build sound? just need opinion on pulley size thanks
Is this a DD or no?
NIC is not DD friendly.
Not even non-tuner friendly.
I'd suggest the XPZ over the NIC.
be a real man and drop a 2.4 on there
The guy posted a serious thread and appears to have done his homework.
Based on that, your comment was unjustified.
all ready set on the nic cam 1 cause its diff then everyone else 2 i can run a smaller pully 3 has a nice sounding idle and im ok with the way it will drive thanks anyways but for my 20 deg timing can i run a 3.0 or do i have to use like 3.1
Different isn't better.
Pulley size doesnt matter.
Its not about how it drives, but how it needs constant attention to the tune and your wideband.
Start with a 3.4 and a wideband.
Then see how it goes from there.
