P4020 - Catalyst Converter Below Efficiency Threshold (Bank 1)
YMS1975
So I got a P4020 code (Catalyst Converter Below Efficiency Threshold [Bank 1]). Is it safe for me to assume that "Bank 1" is the pre sensor, and not the the post?
Also, just to confirm....I want to make sure that there are only 2 oxygen sensors on my 2005 Grand Prix (Base Model).
Lil' help?
Make sure you don't have any exhaust leaks after the cat.
It will also throw a cat code.
Mine was leaking between the cat and rear o2 sensor.
Repaired the leak, code never came back.
Cool.
I'll give it a look-see. If I don't see any visible leaks; then I guess I'll have to end up replacing it and the O2 sensors. I know the code has nothing to do with the 02 sensors (as matt5112 pointed out) but it's probably the original ones, so...while I'm down there. :th_crazy:
