I800C0LLECT
Audio Moderator
Indeed... the big 3 will also go a long way to reducing/preventing headlight dimming.
I agree 100%. BTW, your name looks familiar. You on any audio forums at all?
I don't. Proper grounding is what you need to get the most out of your alternator. We don't have anaemic wiring like our import counterparts. That means maximizing the contact between the wire and mounting point. You can start by soldering the wire and lead together...and I mean you get a torch out, blast the hell out of the lead and make a solder soup inside it before placing the cable inside.
I will agree that the grounding point below the battery is pretty weak.
