Re: "Project" PRPLHAZ
Alright so i'll update a little bit...i got ~2 hours before I have to be to work.
Soooooo back on Feb 24 I had a Viper alarm put in. The model number is 5902V...awesome system. I had a local shop do it that's very reliable and does good work. I've bought all my stereo equipment from them so they gave me a pretty damn good deal.
Couple little things about it.
Up to a mile range. Best i've gotten is about half a mile with buildings and shizz in the way...not bad i'd say.
2-way remote...legit LCD screen in the remote which is rechargeable. Also tells what zone was disturbed if the alarm was to go off. So if a door was opened it will say "door trigger". If a shock sensor is triggered it will say "sensor trigger."
Aside from having the door triggers it's also got a trunk trigger if someone was to open it. Has 2 shock sensors which is nice because the whole damn car has vibration dampener and the vibrations don't get around the car too well.
Also has a dual stage infra-red sensor. Has 2 "bubbles." An outer which would be outside the car and an inner which is inside the car. If the outer field is disrupted it does a warn away chirp where the alarm doesn't actually go off but just beeps to let people know what's up. It also sends a message to the remote when a warn away event occurs. Back to the bubbles...if the inner bubble is disrupted(remember inside the car) the alarm will instantly go off. This means if i'm gonna run in the gas station real fast and dont wanna have to roll the windows up, I can knowing if someone tries to take stuff it's going to go off.
Speaking of running inside a gas station the system has a "pit stop" mode where I can activate the remote start with the car running and take the keys out of the ignition and the car will stay running. So say i'm running in the gas station fast. Pull up, put the car in park, release brake, activate remote start, take keys out of the ignition..car stays running, get out, shut the door and arm the system and go get meh drank, or chips, or whatev....kinda like it. There's plenty of other sheet. The manual for the thing is like 60some pages. Google the model number if you wanna know more about it.
Not really any pix to show here except the remote.
Just changed the name tag on the remote. It said "GTP" before. Now it says "Purple Haze" lawlz Also got a case for it.
