T
TDCRacing
Guest
I dony know what to say or where to start. Laptop is on the way so i will have more detailed info to come soon via hpt.
The car runs fine at Pt with the occasional hessitation from a stop under medium acceleration. It has once died on me when it did this.At the time I had 2 codes.one was a tps low voltage and the other was a 02 b1 slow switching. I reset the codes and they came back.who would have thought right? heh...anyway....changed out the tps to the stock one vs the one that came with the zzp tb. That got rid of that code. Redid the wiring on the o2 sensor and that took car of that code for like 3 days now.
During the problem with the o2 i saw my 02's basicly just sitting in one spot at idle. wich was around 320ish...didnt have long to look....
actually before i fixed any of the problems i started to have a studdering problem at medium PT to WOT.the car just hesitates and goes no where really.ummm how can i describe it...it shakes when accelerating. Went over to my brothers house since he has a laptop that works and noticed that the rpm's would go up and down rapidly probably in about 50 rpm increasements/decreasements. the o2's would also go to around 980 to 1000. totally not where there suppose to be. I had them tuned at WOT to around 910. and while i was tuning i had no problems with the engine or performance. just a little heasititing every now and then from a stop wich kind of went away.
Things i ruled out.
MAF switched back to the stock one from the LQ$4...same problem.
TPS
IAC-same
IAT- just figured i'd name it so someone less experienced wouldent.
plug wires.
Pulled the plugs and they could probably use a changin. there 104's
checked and made sure sensors were plugged in injectors ect.
No ses light with any new codes. will get a scan and a video of what the car is doing up as soon as my toughbook gets here.
again this problem started one day when i was just cruising around...It did start when the codes were present...but the codes had been there for quite some time before anyof this started.and after they were fixed the problem still wasent.
Things i ruled out.
TPS
IAC-same
plug wires.
