Sinister Performance
Man that was ALOT of reading lol, but i hope i dont have this problem from INTENSE? I'll be getting HPTuners soon, hope i can disable cat diagnostics? if it's not allready?
When you get your HP Tuners setup, hook it up and scan while you drive with your INTENSE PCM. Keep an eye on your short and long term fuel trims, and also the B1S1 O2 sensor's voltage readout. If you see the O2 sensor voltage go high (above 0.800v) and stay there AND at the same time you see your short term fuel trim (STFT) and/or long term fuel trim (LTFT) go way into the positive and stay there, then your CAT and post-cat O2 diagnostics were NOT properly disabled in the INTENSE programming.
-ryan
