05grndprix
anyone change out the snout to case gasket??? if so anyone know how to find a part numbe rfor advance auto parts??? i just called and the guy knows nothign about cars
You can use RTV, I would suggest the Ultra Gray made by Permetex. This is what I only used back in the day, still works great, and it does cure, and it does seal. NEVER had had a issue with any of my M90s out there.
You ONLY want to do ONE SIDE of the rotor pack, the side the snout mates up to. A thin light bead of sealant too...don't over do it.
Its zero tolerance on these parts when they go together. You do want to use a anaerobic sealant though, to correctly do it. Loctite 518 is what I would use
~F~
So, why wouldn't you just do it right the first time? Just because you did it with RTV doesn't mean it's right.
I don't offer bad advice, ever.
~F~
LMAO, alright Jason.
I'm going to take the high road on this one, and not even post what I had typed as a reply to your comment. I know you will reply to this, cause you always feel you have to get the last word in. I'll chat with you in person next time I see you Nick, don't worry.
~F~
