Transtec View on Scotchbrite
Rubber Accumulator Seals
The lathe (square) cut accumulator seals in this kit are TransTec’s aftermarket design seals. The
dimensions are slightly different, and the material is more abrasion-resistant than the OEM seals. The
design of these seals was improved because of occasional wear problems with the OEM seals. The
transmissions most affected are the 4T60/E and AXOD, due in part to the design of these accumulators.
The following steps should be taken on every overhaul to prevent premature seal wear:
1) Always rinse the case to remove any soap film left from the parts washer. The soap acts as an
abrasive that causes seal wear.
2) Always resurface the accumulator bores with Scotch Brite®. A smooth bore has no place to hold
oil for lubrication. Without lubrication, seals wear out prematurely. (Scotch Brite is available through
parts stores, body shop suppliers, or tool distributors).
3) Always check the accumulator piston-to-pin fit, especially on the aluminum pistons in the 4T60/E.
Any wear here will cause the piston to wobble in the bore and wear out the seal.
Source:
http://www.transtec.com/tech_insert/IS-4T65E-5.pdf
