LTFT at WOT still 0?
Also you're probably well outflowing a stock GTP so you're probably at parts of the MAF table that are normally never reached by a stock GTP.
aim for 11.2-11.6
The stock AFR in a GTP begins in the mid 12's and starts dropping over time if I remember correctly. The VS cam or any cam for that matter requires that you tune your MAF table.
I see, so you're talking about commanded AFR, or are you using a windeband?
but my WOT fueling is fine as stock. Crazy.
