Spaceghost
So my mods are the following:
2004 L32 Short Block with L67 Lower Intake Manifold and Gen III M90
Self Ported Lower Intake Manifold
Self Ported and polished supercharger. Inlet Ported to 75mm.
ZZ Performance Improved Supercharger Coupler
Thrasher 3.4” Press On
W-Body Store 75mm Cadillac Northstar Throttle Body
W-Body Store 85mm LQ4 Mass Air Flow Unit
JMB Cold Air Intake 4” Diameter
K&N 4” X 7” Cone Filter in Fenderwell
ZZ Performance Modified 1.9 Ratio Rocker Arms
ZZ Performance Stainless Steel Long Tube Headers
ZZ Performance 3” Downpipe with U-Bend Delete
Magnaflow Catalytic Converter
Borla Stainless Steel Exhaust
ZZ Performance O2 Simulator at Cat
Digital Horsepower v1.0 PCM
ZZ Performance Shift Kit Switch & Wire
Hydrostat 180 Degree Thermostat
Smoothflow Underdrive Water Pump Pulley
Autolite 103 and 104 Colder Plugs
Custom Tuning Performed by Dave Richie, Lititz, PA
W Body Store Poly Motor Mounts
I will be changing over to a higher flow fuel filter and going with either AL 103 or NGK TR8 plugs. PRJ Wires and I only run 93 octane.
Can I change my 3.4 over to a 3.3 without creating a ton of knock?
