Rich at idle
shawnschuldt
my car loads up on gas at idle and i read somewhere that there is a setting in hp tuners that controls the minimum pulse width, but i cant find it and my injectors wont go below 1.8ms
It's been a while since I've had the non-beta version, but it's under engine/fuel/ flow rate vs. kpa
What are your fuel trims looking like to be "loading up"?
all day yesterday anything below 1875 maf Hz would go straight to -16.4 but the rest of cruise was fine, and for the record i have 65# injectors.
but on the other hand it seems like it has worked what ever was wrong out, because the ltft are now back within normal ranges today
i take that back when after start wideband goes down to 10 which i dont thinks it reads below 10 and stays there for a period. Is there a table in ho tuners that adjusts startup fueling?
The car is supposed to run rich immediately after startup. It also has a decay table which brings it closer to stoich after a certain amount of time. I found when I messed with the startup AFR table, I had starting issues, especially when cold.
