if you ask me, run what ever you want, its your money.
3k is a myth and a waste, even more so with synthetic.
I run conventional Valvoline in both my 00 GT and my 95 Bonne, and use either a Wix or Delco filter. I won't even run a Fram on my JD walkbehind. Had too many issues with those in the past (oil pressure dropping out, filters coming apart internally, etc.).
And JoRoW, correct me if I'm wrong, but you change out that oil pressure sensor with the new oil gauge's sensor behind the oil filter housing while there is NO oil in the car right?
The oil matters less than the filter.
