JoRoW's '01 GT - update 6/26/13 new track times
Re: JoRoW's '01 GT
Dont have any vids...It is running very rough right now. I also have a big exhaust leak from the SD headers and Im pretty sure i have a vac leak i need to hunt down. But it does run! Hopefully it will run a little better when i can put the L67 injectors and new tune into it. Also for anyone looking at top swapping, The screws from the GT ICM do not fit into the L67 coil pack bracket. I had to tap new holes in it. The MAP extension harness also didnt fit so i had to take a dremel to the plug to make it fit.
Re: JoRoW's '01 GT
Yea its kind of a rats nest of wires right now, but oh well. And yea Spectre is sh!t. O'rilleys has a thing where you get a free K&N oil filter if you buy an air filter from them. either that or i'll just buy another cheap one.
Re: JoRoW's '01 GT
Color doesn't matter...they come in 3 different sizes...in 4 different forms...red/blue/silver...and a offroad stainless steel mesh filter. I have a mongo dong huge filter on there...but was done with the CC deleted...unless you have an elbow off the TB...only your same sized filter will fit.
Re: JoRoW's '01 GT
I do have an elbow but it won fit over the coupler thats like perma-stuck on the TB. Ill see if they have any red ones. if not silver. Maybe silver will match better...
Re: JoRoW's '01 GT
Went and picked up a silver spectre filter. Its all good and running now with no vacuum leaks :D one problem...IM STILL USING MY STOCK PCM AND INJECTORS BECAUSE F*$($&$ WBS HASNT GIVEN ME MY INJECTOR CONNECTORS EVEN THOUGH I ORDERED THEM 3 MONDAYS AGO!!!
/rant
I drove it around (while scanning for knock) with the supercharger belt on. The whine sounds good at half throttle :D
Re: JoRoW's '01 GT UPDATE: Top swapped.
Yea sometimes WBstore can be slow, took me nearly 3wks to get a downpipe but anyways sounds good man. Really cant wait to top swap myself.
DONE!! Oh man its fun. thanks to Kejross I finally got my connectors. runs like a champ with no knock on a WBS tune :D
Next thing is to take it to the track and run down some unsuspecting cars :p
Ok well I finally fixed all my exhaust leaks, sounds a lot better. Going to the track this saturday, hoping for low 14's. Or at least to beat my friends cobalt SS/SC (intake/full exhaust.) My aeroforce said mid 14's @ 97mph.
VID! (sorry in advance)
Top Swapped Grand Prix GT 0-90 - YouTube
If you're going to the track saturday to run 14s you might as well skip it and come to Ice Cream Cruise so you can lose to hondas after..
Not sure why it was so loud...took it with a digital camera.
Spade: 2 hour drive to lose? nah.
