txslow6
Switched to a racetronix pump and the pump isn't priming. The one before had stopped and wasn't priming either.
I have tried with the caspers rewire and the factory wiring and still no luck. The fuel pump fuse is good. What should I check next? :th_scratchhead:
I will be pulling the pump back out to double check connections, but in the meantime any suggestions?
