Monte Carlo Cross Bars....
I meant the GP ones lol. and in my wreck they didnt bend.. il post pics....
My bar is still straight if you can see it...
I'm not debating either way because I have no idea, but this photo doesn't show the wreck near the point that the hood is going to go through the windshield. The core support doesn't seem to be hit in this case, so the braces wouldn't have been able to buckle as mentioned to cause the hood to push up. Just observing, though, as I said. It matters not, to me, what they're for.
The core support was bent in two. I would know.... also the point of the picture was to show that the diag brace was still straight and the hood was bent. And also that the hood was still attached. When i went to get my performance parts, i had to cut the cable and take the hood latch off to get the hood to release.
Guys ...I started as an H body owner. We were jealous of the upper motor mounts etc and some engineering folks looked at the bars. To add upper mounts, I'd have to have added some bracing. The mid 90's Caddies had a small angle brace as well.
Then I realized that with my slightly modded front mount that I had less movement than a fully poly'd engine. No thanks..no need for that upper get in the way mounting system.
Im lost bill.... lol
So because I have the zzp ones my heads gonna get chopped off? I don't think I'm buying it either... Bills reason actually makes sense, and well them being there to fold the hood doesn't. I've seen soooo many Grand Prixs with front end damage down at pullapart and the hoods all folded just fine without any assistance from the diag braces pushing them up. And how is the hood just gonna slide back and cut a head off? Its locked with the latch in the front and out of all the folded hoods and front end wrecks I've seen of these and many other cars I've never seen a hinge shear the pivot pin.
Exactly...the hoods will bend upwards even if these crossbraces do not :th_laugh-lol3:. They do serve a purpose as to help stiffen the front end
The hood is going to crumple and bend without the braces since its mounted via the hinges and the release. Its not going to push straight back unless its a seriously freak accident.
