Zef_66
Also this "misting" property your talking about that the SC oil does, if the rotor packs are spinning 10-12k then the gears are going so fast the oil will be picked up and thrown around the snout so much that it will lubricated everything without the need for "misting". The fluid also fills up to the middle of the gears so half of them are already submerged, positive lubrication there.![]()
My guess on the misting is that the oil needs to be thin so as to not create a HP loss or create excessive heat. And because of this viscosity, it will fly off the gears when running 10-15k RPMs. So having the oil mist basically means that the oil is getting suspended in the air inside the snout. Kinda like water particles suspended in air makes fog. This allows the thin, fragile gears inside the snout to still be lubricated from the oil mist inside the snout.
Again, not a concrete explanation of it. But it makes sense in my mind.
