redynscire
Banned
what is the best way to remove the main caps..?.they're pretty tight fit
Thats it.<
What OP meant was... They are already marked and don't need marked again.
i got the caps off.. good idea though, maybe try that next timeDon't know if you got the caps off or not, but I ended up making a slide hammer to pull them off.
I used a flat peice if steel with holes drilled the same width of the cap holes. I threaded the center to put a long rod on it to make the "Slide" part with a 2" dia round stock with a hole in the middle. At the top of the rod I put a couple of nuts and washers for the "Hammer" part to hit on.
I used concrete anchors that are kinda shaped like a bell at the bottom of them and have a "sleeve" that goes over the body. Slide the stud part into the cap hole, slip the sleeve in the holes, put your plate on and secure with some washer and nuts. Once you get it tight, start hammering upward, and the caps come straight up and you don't have to worry about damaging the caps.
If you want I will try and get a pic for ya.
I hope this helps.
