my 97 regal gs
Sweet Regal I go a 98 with 64,xxx miles. So what times are you running? Also I was reading on RegalGS.org that header are a pain on these guys. How hard/long did yours take. Im debating them if my bonus is good enough. Still nice Regal
Have not taken my car to the track yet. But I'm hoping for mid to low 13s. Headers arnt to bad to do front goes in easy, and the back ones its best if you drop the rear sub frame with a jack sporting it of coarse. And the slide the header up from under the car.and make sure when you putting the crossover pipe on that you leave the front and rear headers loose. Then tighten everything up. And do.t forget some copper rtv for the gaskets.
zzp stage 2 ic finally installed
Re: zzp stage 2 ic finally installed
Should have cut the bumper support to move that IC Rad up, looks like its gonna scrape. Other than that, looks prety legit.
mine doesnt.
stock ride height though. With ebaichs it might be a problem.
also, have you closed the hood in those pictures?
Asking because the flex piece doesnt look bent sideways like mine does...
its deff a big butt dyno improvement. and i dont have bumper supports in the front or rear. LOL that's where i wanted it to sit. it still sits above the sub-frame so i am good to go with clearance.
in the summer use ditilled water and Water wetter. In the colder months use dexcool
Well thats good, Id hate to tap my new FMHE coming out a driveway. Id loose my mind. Did the install go smoothly? Did you use RTV+ the garlock gaskets? My IC install is soon.
yeah i thought about using distilled water and water wetter but i was not sure. and yes i used rtv with my gaskets as per zzp's instructions
I think you should fab up some shrouding.
Right now i'm sure your ECT's will sky rocket and your post blower IAT's wont be as low as they could be.
actually i have not seen a change with my coolant temps. i am running a 160 drilled t-stat.
fan settings?
Did you have the shrouding before the install?
Do you like to play Green light= WOT redlight = stop? :D
fan settings?
I am not sure on my fan settings. Shrouding has been gone since i have owned this car. No issues with coolant temps. And i don't fined my self doing to many Green light= WOT redlight = stop runs lol.
