mezzoni
1. is a gasket set necessary when installing speed daddy headers?
2. what gaskets should be replaced when doing a top swap? can any be re-used?
3. what bolts can be reused on a top swap from an l67? which should be replaced?
4. do you need a top swap wiring harness when doing a top swap (that $35 one on zzp)?
5. if your car is tuned for a 3.6 but your running a 3.5 on a top swap there will be a greater chance of knock correct? also can i run a 3.5 with just headers intake plugs wires and tstat on a top swap?
6. are drilled and slotted rotors even worth the price if your not getting a bigger size?
7. does having too powerful of an amp affect speakers in a negative way?
8. whats your favorite brand of speaker?
(im in very much of a learning mood tonight lol)
