So question, if you already have a 9007 HID setup, with a relay harness, and decide to do a retrofit, once all that is said and done, do you need anything else other than new bulbs?
On the corners or housings themselves? I used rtv to seal your capsules not oci butyl tape if I remember right. I also sold you the complete retro for $200 since it one of the first few I did right? Cant really remember it's been so long ago.
You need,
9007 bi xenon relay harness,
H1 bulbs
Your ballast will work fine you just need a different harness and H1 bulbs to complete your retro
I already have a 9007 bi xenon relay harness. I ordered a 9007 bi xenon kit w/ harness from VVME.
So I really just need H1 bulbs.
I think they used a no name DDM bulb. From looking at a thread full of temp and brightness comparisons, the DDM bulbs seemed to run cooler than the morimotos, although they are dimmer. While heat is a likely cause of that damage, a major contributing factor to consider is UV damage, which 55w usage boost significantly. IMO, no matter what brand you choose, 55w is a bad choice for the minis, they're plenty bright with 35w with no risk of damage.Thanks for the info there that looks pretty nasty. What type of bulbs were used, morimoto bulbs are supposed to be a cooler running bulb I wonder if those would do that too. Over time I guess they still probably would end up ruining the bowl like that. Guess that's why it says 55wt kit not recommended on the trs website.
tommy hows the money making business going so far? get any takers? lol
So clean what would you say is the best bulb as far as brightness goes. I don't mind replacing bulbs more often if they're noticeably brighter.
Well Matt only sells Morimoto bulbs and OEM bulbs, so... It's gonna be the morimotos. They really are great bulbs.Well what bulb does Matt at TRS recommend?
FWIW my DDM's are pretty damn hot.
I agree that the morimoto bulbs are by far a superior bulb to any other aftermarket bulb out there. They're brighter and last longer than all the competition. Running a little hotter isn't really much of an issue until you push into the 55w range anyways.
Oh he doesn't sell the Philips bulbs?
This is the comparison that I'm going by, Done by one of the most respected members of HID planet, and Matt has already seen the comparisonsI agree with the brighter but Matt isn't the kind of guy that goes around promoting his products to be better than someone elses. I'm pretty sure he does plenty of business and doesn't need to make false statements to sell products. If he said Mori bulbs run cooler well then I believe him. What temperature chart are you seeing that said Mori's run hotter I'd like to forward that to him and see what he says about that.
At 35w the mori bulbs in the mori H1's seem to run very cool. I left them on a good 20-25 minutes while stationary on rojo's retro and when I touched the shroud it was only warm. The projector lense was pretty hot but that's kind of expected imo.
