what temp should i be running at
nicks98gtp
i just bought a 160 degree thermostat and put in my 98 gtp. the old one which was a 195 degree would run around 210 sitting still and around 185-190 when moving. the new 160 seems like its running a to warm at a stop it sits steady right around 200 and running hold steady at about 180-190. not sure if this is correct but seems warm. anyone have any advice? thanks guys
Your fans turn on at ~216F low speed and ~228F high speed. If you aren't driving, that is going to control your temps.
Unless you reprogram the pcm.
