Couple of questions....
Koniig
Brightening up your day.
Alright. My 2007 GXP gets extremely hot near where my feet are when I drive on a daily basis, so I am forced to redirect it by turning it up to 90 and using the defroster so it's not blasting in my face either. I know it's naturally a hot running engine, but anyone else have the same problem? I want to make sure I'm not the only one if it's a common problem. So, any ideas how to get the footwell area to cool the **** down?
My other question is the foglights. Currently, with both sets of HID fogs I've had, I've been forced to tape them in place behind the projector because they don't seem to snap into place. It's like they are too big for the projectors. So my question is, any of you guys with HID's in your fogs, how in the hell did you get them to stay in normally??
Thanks guys.
maybe there is something i am not understanding here but uhh why turn it to 90 when you could turn the AC on and set it on the floor setting?
As for the heater, you'd probably do good for a good radiator flush and fill. My 2002GTP did that during the summer, but I combatted it with a flush, and by cranking the AC on..Never got over 185 while driving, or over 195 sitting.
And for the fogs, my HIDS didnt fit too well, so I used a piece of thick rubber(maybe 1/4" thick) and put it between the Housing and the bulb, and solved all my fitment issues.
I drive with the windows down, I never have the AC on lawl. THis beast burns enough gas. :D
Awesome I will definitely try a radiator flush.
And as for your suggestion with the fogs, did the rubber have adhesive on both sides or something? Like how did the bulb stay in with a piece of rubber spacing it from the little slots in the housing to screw the bulb into?
