Gtp redux'd
z3r0
okay here's ****ty night pics
but i fixed the hud, dic and painted the wheels and arrow head black
-- Fri Apr 01, 2011 4:04 pm --
oh and drl delete
-- Fri Apr 01, 2011 4:18 pm --
some update pics....
i'm def gonna debadge, however i'm thinking of getting the gtp badge overlays and putting them on the door in the right spots unlike my real badges are. and in reflective black. the real badges will be moved elsewhere
i plan to debadge today....
nope. i debadged her. and i've only have her for 5 days now. i have a bit of trouble with working on car when i work since i do 10 - 12 hour shifts 4 - 6 days a week
here's the old gtp i have 3 years ago
Mr.Angry.GTP said:
Didnt know ya b4, but welcome back anyways...
trip down memory lane
no particular order
FWI
pollished fuel rails
when i spent 2500 on brakes
i had to pwn kyle back in the day
mmmmsexy
eww stock
rockers
this will be implememnted
i tried to make tan turn black
pc'd grills
cool
sexy sauce
i need more reflective black!
Lookin better, now get it painted all the same color :p
Any... could just be my opinion... but are you REALLY gonna put the GTP emblems on the inside of the doors :confused:
cb and scanner mounted up. just need to wire everything. i have a powered speaker for the scanner, that i'll use to hear it since it's in a confined space. and i don't need it for the cb since i'll use the scanner to pick up the waves. cb is just to transmit.
this is still pretty rough the way she sits in there. but it'll be refined more.
but finally got the mounts worked out
-- Thu Apr 14, 2011 5:49 pm --
1997
Master cylinder/fuild reservoir setup is different than on newer years
Antenna on rear fender instead of in rear window on most 97’s
Unique PCM for this year only, removable chip making case learn unneeded
Large windshield washer fluid reservoir on top of battery
Alternator and mount is different than the newer years
Coolant temp display in the car starts at 100
* The 97s DO NOT have tire pressure sensors. The 97s have the Delco Delphi ABS system, which could not handle the GTP power for TCS. So TCS was disabled on the 97 GTP, but works on the GT and SE. The "Tire Pressure" light was part of the Delphi ABS system; it did not sense pressure but noticed differences in tire rotation speed. When the Delphi was replace with Bosch, TCS was enabled but the "tire pressure" light was lost.
* Some of the 97s had a prop rod instead of struts to hold up the hood. Some had under hood lights, too. The under hood lights were phased out after the prop rod, so some (few) have both struts and an under hood light.
* Rear fender mast antennas were common for 97s because they ran out of rear window antennas at the factory. Those with mast antennas were credited $15 on the sticker.
*Courtesy of Gene Orlanes
Transmission input shaft is a little stronger from a better O-ring groove radius
Complex EVAP system that uses an extra part not found on newer GPs
M90 has an extra vacuum port
AAA manual Passanger Seat
AG1 Adjuster Front Seat Power
AG6 Adjuster Front Seat Power, 6-Way, Lumbar 4-Way, Driver
AK5 Restraint System, Front Seat Inflatable Driver and Passenger
AP9 Net Convenience
AR9 Deluxe Front Bucket Seat
AT5 Seat, Rear Center Folding
AU0 Lock Control, Remote Entry
BA5 ORNAMENTATION, EXTR CUSTOM
BZ7 VEHICLE GM PROD WEEK 16 GM VEH PROD WEEK 16
B19 ORNAMENTATION, INTR, CUSTOM
B4S MERCHANDISED PKG 'GTP' PKG 'GTP'
B72 ORNAMENTATION, EXTR MLDG BELT REVEAL COLORED
B90 ORNAMENTATION, EXTR MLDG, SIDE WINDOW REVEAL
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CR1 LAMP, INTR FRT DR WARNING
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC System, Air Conditioner Front, Manual Control
DD8 Mirror, Inside Rear View Light Sensitive
DG7 Mirror, Outside LH and RH Remote Control Electric, Black
DH6 Mirror, Inside Sunshade Illuminated LH and RH
DK6 Console, Roof Interior
DL5 Decal, Roadside Service Information
D55 Console, Front Compartment Floor
D81 Spoiler, Rear Aero Wing
E28 Assist Handle
FAI Plant Code Fairfax, KS, USA
FE1 Suspension System, Soft Ride
FR2 Ratio, Transaxle Final Drive, 2.93
IP2 TRIM,INTERIOR DESIGN (IP2)
JL9 Brake System, Power Front and Rear Disc, Antilock Front and Rear Wheel
KA1 Heated, Front Seat
K34 Cruise Control, Automatic, Electronic
K68 Generator, 105 Amp
L67 Engine, Gas 6 Cylinder, 3.8L, Multi-Port Fuel Injected Supercharged V6
MN7 Transmission, Automatic 4-Speed 4T65-E, Heavy Duty
MXO Merchandised Transmission, Automatic Provisions, O/D
NB6 EMISSION SYSTEM, CALIFORNIA, TIER 1
NC5 EXHAUST SYSTEM, OVAL VERTICAL TAILPIPES, CHROME
NP5 Steering Wheel, Leather Wrapped
NV7 STEERING, POWER, VARIABLE EFFORT
QD1 Wheel, 16 x 6.5 Aluminum
QVG Tire, All P225/60R16-97H BL R/PE ST TL AL3
R7K Sales Item no. 36
R7N CONTROL - SALES ITEM NO. 39
R9V CONTROL - SALES ITEM NO. 96
TR9 Lamp Group
UH8 Cluster Instrument, Coolant Temperature, Trip Odometer, Tachometer
UK3 System Steering Wheel Accessory Control
UQ3 SPEAKER SYSTEM, PERFORMANCE ENHANCED AUDIO
UT6 RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
UV6 Head Up Display
U40 Display, Digital Direct Readout, Trip Monitor
U77 Antenna, Rear Window Radio
VB7 BUMPER, FRONT AND REAR SPORT
VG6 BUMPER STANDARD, LABEL, IMPACT 5 MPH
VG8 Vehicle Label Notice To Buyer
VK3 License Plate Mounting Package, Front
VY7 Knob, Transmission Control Lever, Leather
V73 Vehicle Statement USA/Canada
WX2 SALES LEATHER APPOINTMENTS
YF5 CERTIFICATION, EMISSION, CALIFORNIA
Z7M MODEL CONVERSION, PONTIAC GRAND PRIX GT
1SD OPTION PACKAGE 04
1SZ PACKAGE OPTION
12I INTERIOR TRIM GRAPHITE (12I)
122 TRIM COMBINATION, LEATHER, GRAPHITE (2) (92)
15P WHEEL COLOR SILVER METALLIC (91)
41U PRIMARY COLOR, EXTERIOR, BLACK
6JT COMPONENT COMPUTER SEL SUSP SUSP(6JT)
7JT COMPONENT COMPUTER SEL SUSP SUSP(7JT)
8FW COMPONENT RR LH COMPUTER SEL SUSP (8FW) SUSP(8FW)
9FW COMPONENT RR RH COMPUTER SEL SUSP (9FW) SUSP(9FW)
decoded the rpo
anyone know what the option packages and sale items
http://www.youtube.com/watch?v=eYXmczIcDuM
just the zzp catback
tried it out w/ plastidip before i took the plunge w/ bbq paint. rustoleum actually make a pretty nice product, and this is semi gloss vs flat
here is before
after
i'm glad i did it this way. i was flip flopping for a few hours yesterday. but owell
Just a thought, if your going to "murder" the car out, you need to tint the tails to match
I prefer the chrome tips to the black ones, looks like there isn't any exhaust in the picture, but if you can actually see them in person it wouldn't be as bad
my tails are already being done by flip. i had that setup the 2nd day i owned the car.
and the tips you can see in person, its just the camera angle was a little weird.
also flip has a bunch of stuff that he is doing for me.
