02BlueGT
As title states, i've got some questions before i actually do the work, I took an entire week off of work, but I hope to finish in 1-2 days, anyways on with the questions:
1. I bought head studs, how tight into the block do I screw the studs, and what should I torque the nuts to
2. I bought a HP tuners and plan on running the L36 in injectors for now(so I can get it up and running before I start cutting and splicing fuel injector wires) Is this ok?
3. What should I set the base timing to in my GT pcm, or should I just flash an entire GTP bin and start from there???
4.Should I coat the head gaskets with anything before assembly?
5. The top swap setup I bought only had bolts for the belt pullyes, are the UIM bolts on a L36 the same as the stock supercharger bolts on a L67
6. Does anyone have a good picture/diagram of the L67 vacuum routing?
7. An tips or suggestions before I start?
Thanks in advance for any answers
