Remnant King
I am probably going to get some if not a lot of s*** for this, but here goes.
I am planning on doing the brake upgrade sometime in the near future hopefully, sometime in the summer, or whenever I have the money.
As of now, I have the factory OEM 16" wheels on my car, and I am probably going to get 18" in the future, but the 16's will always go on in the winter, which means I'll probably not be able to do the GXP upgrade.
That leaves me with three options, the stock replacement, the 12" upgrade, or the F-Body upgrade. As of now, I am really considering doing the F-Body upgrade and doing Option A, which is just picking up the F-Body Calipers and using them. Option B seems a little more expensive, and it's definitely going to be a little more complicated. With Option A, will I need the Banjo Bolt, or is that only for Option B? And with that, they mention something about this fitting on 16" wheels with the correct offset. Will this upgrade work with the OEM wheels?
With the rear brakes, it mentions something about the GXP caliper and brake set up, that will require 17" wheels, right? If so, do I just get new rotors and just to change them?
And since I am going to try and upgrade the brakes, I might as well get the SS Lines, do I need to know anything else about them?
The OP in the Big Bad Brake Thread recommends The EBC Red and the Hawk pads, is there one better than the other, or will either work? I was leaning towards the EBC Red, without knowing much about them to be honest.
One last thing...The E Brake doesnt work, not sure if it doesnt bite hard enough, or what but when I press the pedal down, the car still moves even without pressing gas. What could be the problem, and will that effect anything when upgrading or in general?
