Intercooler install questions
shawn3091
I got the wbody store ic install kit, im trying to figure out how the hoses should be routed. would the hot coolant from the core go into the top or the bottom of the heat exchanger? and would my resovoir go between the pump and the core, the core and the heat exchanger or between the heat exchanger and the pump?
Coolant always flows into a heat exchanger at the top. That way the pump pulls from the bottom and there's always fluid there, even if the system is not 100% full.
thank you both, i got it all on the car, went from bottom of heat exchanger to pump inlet, then from pump to core, core to resovoir then to the top of the heat exchanger, just need to wire up the pump to my relay and it will be ready to go
i wired up my bosch pump and turned it on for a second and it seems really loud, im not sure what normal is, anyone have a video of the pump sound?
i will have pics up here when i get around to it :p and i beleive im going to need to cut the bottom layer of my hood out for it to shut :th_depressed:
