ljmonnin12
So while I was working on my car today I found this random plug below the hood release and I have no clue what it could go to.. Any ideas?
All of the GP's were standard for that and it would be connected.Could be to you airbag module
I believe it's for the temp sensor my GP has it right under the hood latch also.
would the temp sensor only be necessary for the dual climate control?
Yea but if his car was ever in a accident and when they repaired it never replaced it
I was thinking the same, there would be a light. But finally checked my GTP and the same plug is not plugged into anything and the connectors are corroded. The temp sensor on the Regal is located at the front right on a piece between the AC Condenser and the bumper. It has the same style connector and the same color wires so I think you're good.The airbag light would be on in that case. OP doesn't mention a light.
