I will never go back to halogen.. Unless the cops make me
Anyone else get sick of typing. My girlfriend says between this site and my ar-15 forums i don't pay enough attention to her. Oh well, just do what i enjoy. We need voice over IP to make it easier. Guess others could not follow it though.
Will do, I'll have this set I'm working on done tomorrow. I'm going to be purchasing a better camera this 3.2 mp 1983 camera doesn't cut it when you're trying to get quality light shots.
I've got a picture of the hi beams on a building however the set the picture was taken from didn't have all the cross beam removed. Also the frosting on the 97-03 gp housings creates two bumps at the cutoff if you don't remove the cross beam and have the projectors basically pointing straight out of the headlight. The housing isn't tall enough when pointing in to clear the frost where the lense isn't clear.
I want to add this pic is with ddm 35 wt H1 bulbs. Morimoto bulbs are significantly better quality! My headlight adjusters on those brackets were also broken thanks to the body shop that put them in when I did the gtx hood.
Hi beams in my garage, garage is narrow so hard to get the full picture of how they'd look on the road. These are the only pics of bi-xenon output I have at the moment.
Thanks for the pics. I look forward to more highbeam pics.
So one of the most important things to keep in mind to keep these retros waterproof is to seal up the back. The lowbeam portion of the headlight gets saturated as water will seep in through the channels between the hood and fenders and it drains right on top of the lowbeam.
What I did was to wrap the back of the projector in foil duct tape to close the gap between the projector and the reflector. I then put the stock rubber grommet over this. I sealed this grommet into place using Permatex black silicone adhesive to make sure the grommets stay seated in their place. I put foil tape of the grommets just to keep them in place as the silicone dries. I took the tape off the grommets after 24 hours.
Now, in between the grommet and the back of the projector I put a generous layer of Permatex silicone as well. This completely seals of the back of the headlight from moisture and since the silicone is flexible it will allow the headlight to be adjusted vertically without breaking the adhesive.
I'm gonna do another retrofit
You will see...LOL
I have no doubt broski. You average a retrofit every quarter so it's about time for one.
...its something down below thats changing
