Before I order?
dengnath
I just wanted to make sure the 03 vogtland spring s will work on my 04. I know several people have said they have done it. Im getting them done at a shop but im taking in the parts, and I just dont want there to be any problems
did u get any vibrations at all, and did they go on like the springs are meant to go on or do they sit in the strut different?
Struts are exactly the same from 97-03 to 04+ as far as strut perch, top mount, and mounting points go. So no vibrations, you will be fine. Like I said on the other Forearm...you will probably do about 1.5" drop
What is the difference between zzps strut mounts for 120 dollars or autozones strut mounts for 60 dollars?
