cleangtp
Banned
Here's some pics for you guys with the black oem style housings installed on my car. I will get output picks maybe tonight. Looks good need to adjust the drivers capsule down just a tad but can do that via the adjuster.
I'm definitely keeping these I'm loving the all black look,
First time turning the all on, this is Morimoto low beam and DDM 880 HID fogs. Didn't get any shots of the bi-xenon, just got them hooked up last night. Had to switch the pins around in the wiring harness (9007 bi xenon relay harness from TRS). I can provide you the wiring if you use this harness.
Drivers lense needs to go down just a bit, no biggy!
DDM 880 fogs with DDM relay harness...
Mori low beam and fogs of course, lenses need buffed haven't even cleaned them yet. They're fingerprinted like crazy!:th_biggrin2:
Bi xenon solenoid activated, cutoff shields down!
You can wire the relay harness to work like factory where the hid fogs shut off when you click your high beams. You can also wire it to have just low beam projectors on but when you click your hi-beams the hid fogs turn on. It has pro's and con's about wiring it either way.
I will continue to post information and answer any questions about what to get and what not to get. This is just my personal opinion, you're entitled to like what you like!!! Enjoy:th_nanana:
