Alright, this is how my motor is set up.
Cylinders 1, 3, 5, the dots are facing forward. Cylinders 2, 4, 6, the dots face toward the flywheel. This also coincides with what you found on INTENSE's site about the bearing tangs facing the oil pan rail. The tangs they're referring to are the notches that the bearings have, that sit in the machined surface of the rods and keep them from moving side to side as you assemble them, not saying you don't know, but for further clarification in the future. Also, as have been said before, you'll have to watch as you assemble the pistons onto the rods as well. Numbers are the front of the piston, so you will have to make sure you put the correct orientation on the correct bank. As you assemble them, rotate the crank to make sure they don't bind up after torquing every two pistons. I do this just to make sure all clearances are checked, and double checked.
I've got 11,000 miles on my build, and it seems to be holding up ok with no issues.
I hope that helps. :th_thumbsup-wink:
You know, at the end of the day, I'm not really sure it matters. I mean, the rods are basically symmetrical. I know someone that put all dots facing forward (just talked to him on the phone) and the engine has 30k on it. I also don't know about the pistons, or if they differ between the states and Australia. I know that I've only paid attention to the numbers that are etched into the top of the pistons, I don't recall any F stamped into them off the top of my head. It seems that if you ask 10 different people how to assemble an engine, you're probably gonna get 4-5 different answers.
I can also quote GM's online service manual, that states "the connecting rod can be installed in either direction", but doesn't explain that the pistons are directional.
I'm by no means an expert, I flub up as much as the other "experts" but I will normally obsess over something until I know it's right. Like I know you're doing right now.
Ah, well that makes sense then. I've never messed with Diamonds....too much coin for me to drop on internals like that. I bargain shop on everything that I buy.
Is it Holden?
You're right, it's not Pontiac, but it'll have a Buick based heartbeat.
Should work either way.
Mine are 1/2 and 1/2. Half of mine are facing one way on one side, the other way on the other side. I have made countless road trips far and near, and many passes down the 1/4 track at speeds in excess of 100 MPH. (who hasn't right)
Several oil chances since my build, and not a speck of copper in the oil. If it, the direction of the rods were wrong with my build, then I would be "panning for gold" by now with the copper from the bearings getting shredded to bits.
Like reptile said...its probably good either way you do it.
The L32 rod bolts shipped out today. I wish the box was bigger, I would have liked to hope in there and go with them. I'd like to go to Australia sometime.
~F~
