3" Downpipe Vibration :th_nervous:
klj5022
KSteelwheelzJ
I got my DP installed by my mechanic on friday and i noticed the other day that undert intial hard acceleration there is a heavy vibration i can feel under my feet then its gone. I can be launching to WOT and only feel it for like 1.5 seconds or i can be pulling off from a light a little quicker than normal and feel the vibration for about the same amount of time. Any ideas?:th_nervous:
Ho bad s that because i dont have the time or tools to do that and i need my car for work so cant afford to have it in shop again right now
Don't get on the throttle hard, it won't hit and you'll be fine. Get it done when you can...then slam the throttle and kill your transmission.
Oh..it'll be a good idea to save up for that future transmission job. :th_thumbsup-wink:
I flipped mine without a lift, just a jack and jackstands (orig one was broken, installes gm upgrade flipped) took less than 2 hours, would have been easier on a lift. I had to have the steering wheel turned all the way to one side, and disconnected a tierod end, made sure to keep it in the same orientation so no alignment was required
