Big Q
Status
Not open for further replies.
GTPJOE90
Hay i was told that i cant put my amp and box with a kenwood 10' sub in the car becuase the alternator is stock and it will blow it apart is this true??then again my car has alll the electrical options for 99 gtpz
I'm not a pro, but with a 10" and an amp you should be just fine with the stock set-up. I've had two 12's with 2 amps on the stock wiring and I was fine. I did have a little headlight dimming but thats about it:th_thumbsup-wink:.
I have 2 square 10's and a fairly large amp and I have no problems. I did do the alternator rewire and it helped some on the lights and the amp is getting more of a consistant voltage.
also i want to put my headunit "kenwood" in also its a kdc335 i believe. so issue? how long does it take to tear apart the dash and install my headunit?
really a deck install should at the most take about 30 minutes, even for a first timer.
As far as electrical issues, there should be none, maybe slight headlight dimming but you will be alright.
if you are worried about dimming, then do the big three. which is upgrading the wire size, from alt to batt, batt to chassis ground, batt to engine block ground.
Dude, your setup should run just fine. You should notice a LITTLE headlight dimming (probly just enough that YOU'LL notice and it'll end up pissing you off... did with me), In addition to upping the wire size, I'd recommend getting a capacitor or mounting a second battery in the trunk... depending on your needs/preferences. These Electrical upgrades/add-ons will help reduce the immediate drain to your alternator/battery. I personally have 1600 watts run off my stock electrical and with my cap I haven't noticed any sort of power drain of any kind, including headlight/domelight dimming. Good luck with your install.
I have a 500 rms amp running 2 12's on the stock battery and alternator and 5000k HID's and I have no dimming/flickering. Gonna upgrade to an Optima Yellow Top soon so I can hopefully get a nice voltage boost. I have done the alternator rewire too.
Joe, I ran 3 Punch 15's, a 600 watt, and a 800 watt amp on mine with no problems. You'll be fine. When you go to install your head unit, watch out for the clips on the back of the dash trim. some will pop off and fall in your dash. But, don't get discouraged because most likely they'll faal to the bottom. Pop off the cover under the dash and they'll be there. Hit on the plastic under the steering column and if any are sitting in that area, they'll go ahead and drop also.
haha i hope yall are right lol i just wired everything today all i have left to do now is to hook the capacitor to the battery and im done. "i have a side post bttery and the 3/8 crimp o ring things dont wanna fit whats the deal?
i just came back from autozone got a bigger side post for my battery she fits!!! Good and an bad news.... Bad news is i installed everything correctly but the box wasnt bumping................. Good news was i didnt have the ground fully secured yet hahaha " i currently just wired it up to hear it work for now" tomarrow ill clean up the wiring and stuff in the truck "inside car is clean" 1 con is it doesnt rattle the trunk like i thought it would lol. for pics go to my site myspace.com/joemama90 click on my picture of my and go to my GTP album thanks lemme no what u think and if u got myspace add me and comment? thanks guys! OOOO ALSO i fixed my fogs today both bulbs were shot got new 1's they look good. also i got bored went back to autozone for the 5th time today and bought a chrome trim kit haha i did my hood and trunk so far lol. check pics out MySpace.com - The Fifth Horsemen - 18 - Male - The Drivers Seat, Illinois - www.myspace.com/joemama90
HERE ARE SOME PICS OF WHAT IM GOT RUNNING AND BUMPING FINALLY! :D "wiring is sloppy for now just wanted to see if it worked. thanks guys i had no idea how to rip the dash apart and because of you guys i figured it out but while doing so i tohought i was breaking it haha :} check my kenwood stuff.
Looks good man. Glad you gat everything hooked up. The paint looks awsome in the flash. Really brings out the flake.
thanks man i just want it to move and bump the tail and trunk but w.e lol it isnt really that noticeable :{ when i open the trunk though its nice haha.
o quick q... when i yanked the stock radio with the eq and the hand controls on the wheel that extra wiring harness is for the wheel correct??? just checkin. thanks
Status
