Dash bulbs numbers
dpzelenak
Does anybody know what bulbs go in dash, gauges, HVAC controls everything, im trying to change all them over to blue leds instead of the red (which i hate) i all ready changed all the interior lights to blue leds and now i want the dash lights to match but i cant if the numbers or the type of bulbs to replace them with, anything will help, Thanks
Got a little info from Sylvania's site:
Instrument-general
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
37
37LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
PC195
PC74
Hi-beam indicator
PC195
Automatic transmission indicator
194
37
Directional signal indicator
PC74
http://www.sylvania.com/ConsumerProducts/AutomotiveLighting/LampReplacementGuide/AutoLRG-Results.htm
I want to say that the lights in the HVAC controls are small incandescent bulbs that are soldered onto a circuit board so replacing them will probably be a PITA.
You are correct on this. Changing just the bulbs will not do anything without the red film removed. You will need to remove the red film some how.
yea i know that the HVAC lights are wired to the bored but someone told me that you can just change the hood(film) but i dont know how, and i followed the Sylvania's site before and it doesnt cover all of them, the ones listed are the common lights(bulbs) that go out, you could just change them but them it'll be muti-colored
So, if you know that the HVAC control lights are wired to the board and that you need to change the colored film why are you asking about the bulbs?? I'm confused...and autistic.
which bulb number lights up the speedometer fuel level and rpm is it any of the general bulbs?
