GOTIT4CHEAP16
I took my extra m90 apart because im about to port the outlet. Its really dirty around the bottom v and inside. What do i use to clean out all the grease?
DO NOT TOUCH THE INSIDE WHERE THE ROTORS SPIN!
leave it alone, seriously.
well then.
Just don't touch the rotors.
they will flake because they love life.
Or as ZZP told me, you guys are using poor quality air filters.
ZZPoopheads told you that Matt? The reason our SC's etc get crappy looking inside is related to two things. First is the EGR, clean a TB and you'll see that the majority of the dirt is behind the throttle plate. That's EGR related. Second is the PCV, which tends to allow a little oil to blow by.
On the rotor area of the casing. Your's looks very scored. If you aren't stuck using that casing, I'd suggest finding another. The thing about cleaning it is the carbon that built up in there is helping to seal the rotors to the case. This helps the efficiency of the blow, not hurt it. Cleaning would hurt efficiency.
