Yeah, don't touch it. It's not going to help your performance any, and might actually cause you problems by building knock.
what you runnin now a days? 1/4 mile wise
There are a lot of things wrong with ZZP now a days.:th_wtf:
~F~
if anything id do the opposite of what this mod is supposed to do. im thinking my knock is from a bad tune, its a dhp 1.5 file with deleted codes for my egr and p0300. never got it tuned after last fall when i finally got her running again.
i havent put my ssic on, but at some point i want to do that as well as finding someone local to put a nice tune on my car. i can tweak the fuel on my own from day to day with my afc, but my PE and timing are probably way off from what they should be. im lucky if i get 18 mpg right now, haha.
wow i just did a little work on my tune...34mpg on the highway and 22 in the city...45* timing ftmfw
This is probably true, mine initially was not adjusted right. I figured out it had to do with where the stop for the BBV on the SC was set at. Not the actual BBV.I was reading that the BBV mod is for the cars that don't come from the factory adjusted properly. It said at full throtle that if your boost guage on the DIC isn't reading full bars, then you make the adjustments to give you full boost. If you are already there, don't touch it. I made the mistake of doing it before I read the whole article and lost alot of power. Luckily I could see where it was originally and got it back right. I'll see if I can find it and put it in the tech section.
