Advice of anything else i can do while i have the sc off
DukesGTP
I went to replace my supercharger coupler the other day because i heard a rattling at idle so i go to remove the snout and find out that my coupler was fine and while removing the snout i ripped the supercharger gasket so off comes the charger. The supercharger wasn't even torqued down and it wasnt the orginial sc because there was junkyard marking on the bottom.It was trashed the impeller blades were rubbing against the housing and they were just toast. I ordered a rebuilt one off ebay and a new sc and tb gasket. I also ordered new injector o rings but i am waiting for the new charger to come in and i was wondering if there was anything else i could be doing besides cleaning? And also i removed my injectors and i need the little plastics pieces on the very bottom of the injector under the bottom o ring because some of mine r cracked and i have no idea where i could get them? Help would be greatly appreciated.
I don't know where you could get the plastic retainers on the injectors, but now is a good time to do your LIM gaskets if they are the original plastic ones.
so long as they injectors are the same for a GTP and a Regal, I have the fuel rain from when i got another 3800 from a Regal to put in my GP. I saved a bunch of parts. So if so, how many injectors do u need? I need to keep a couple handy just in case some of mine take a crap.
YES. for sure do the LIM gaskets if you have not done so yet! if the GTP has coolant elbows which i think they do, get those! when you buy your LIM gasket set, it should come with the injector o-rings, at least mine did. (FEL-PRO)
ummm you could check to see if your front valve cover is leaking and if it is, get the recall done. if they aren't maybe you should get the recall done anyway. and if you already had it done and it's leaking, do them while you have it all broken down. lol.
Oh4compg: i was told to put in those new gaskets and i think i am gunna order them thanks for your help.
Brandonl2000: I would think the injectors are the same if they were both supercharged l67s i would only need 2 injectors but i would think they would have to sell those plastic pieces somewhere. thanks for your help tho.
The injector O ring Retaining disk that break off the bottom do not matter. FWIW
