BoostJunki3
Needs A Turbo
is it worth it? have one? like it?
:th_BSflag-small::th_BSflag-small::th_BSflag-small:The alternator has the same drag no matter how much it is charging on theses cars. So adding more electrical load will not put more load on the engine.
It depends on your desired outcome. An electric water pump (EWP from here on) can use less engine power compared to a crank-driven pump. The reason the electric pump is able to do this is because it can operate off of the battery (essentially a power reserve).
This is advantageous for heavy accelerating, where the engine is temporarily relieved of "water pumping duty" by using the battery power.
It should be noted that an EWP should decrease your MPG because of the inherent energy conversion process. You are converting mechanical power from the crankshaft into electric potential at the generator and back to mechanical power at the EWP. No energy conversion will be 100% efficient, so there are energy losses. In real-world situations, I suspect that the difference in MPG will be negligable between the two pumps.
Of course there are other factors to consider such as whether the electric pump can shutdown when water circulation is not needed. Also, the actual pump (not motor) has an efficiency rating that may be greater or less than the stock unit.
Why do I make such a detailed stink about everything? I'm a mechanical engineer.
im an engineer. i do know everything.
No...
It runs off of your alternator.
Again, alternator power. Not battery.
The alternator spins regardless.
They're 50% efficient.
But the pump draws 6-7 amps according to manu.
Thats 100 W.
Thats 0.26 HP draw from the engine.
ZZP claims it frees up 7 hp.
And not an electrical engineer. :th_thumbsup-wink:
You go on to mention some numbers and statistics which I don't care about because I was only providing theory between the two types of pumps.
Again, read my posts more carefully
I read your post carefully...and if your going to debate something...you NEED numbers and statistics...saying you don't care means just that...you lost.
Done.
