I dont know why everyone shuts this idea down.....Ive been thinking alot about it as well. compare the aztek and gp for a second. very very similar in width and length, both use 60 degree v6 bell housing pattern aztek with 4t65e, same as gp but the versatrak aztek has the transfer case but as long as you have clearance for the t case and the floor of the car, that shouldn't be a problem. So there you are basically looking at "just" a tranny swap.....then since the aztek is also IRS like the GP, the rear drive shaft/diff (torque tube i believe its refered to as) is solid mounted to the vehicle body (so what? fab some poly mounts to hold the rear drive unit in place? wow that would be hard....not), then you have rear hubs, guess what? aztek uses the same hub on the rear as the gp does on the front, ive drawn up some preliminary drawings of a simple spacer/adapter to run front gp hubs on the rear (go from 4 bolt to 3 bolt and a larger hub dia. and space out 0.900" on each side to keep the width the same) and abs would be plug and play. so now u have to find out about cv shaft, stock ones might work or may needed to be modded (i work at a parts store so i can compare hubs, cv shafts, etc all day long lol)
mechanically i think its reasonably doable, the problem i see is getting the electronics to work, its my understand that the versatrak is not suppose to be AWD all the time, suppose to lock and unlock when needed (clutch setup in rear drive unit) and when abs is trigger the rear drive unit disconnects. This could be wired to a manual AWD on/off switch and taped into the ABS with a little work i believe. I have emailed Magna which is the company that produces the t-case and rear drive units for the Aztek and similar GM vechiles but have not heard back yet. I was asking on what kind of power these components are rated for. Im worried about a built GTP gernading the rear drive unit.
But Im like 30 mins from Dave at TEP so you could build the tranny and tcase and I could always upgrade to a different rear drive unit if I had too.....
