deathjunior
Okay so im in the midst of planning my engine build, ive got about 10.5k planned for the motor for hopefully around 450 to 550 horsepower at the crank maby less maby more itll depend how much fuel and boost i run as well as how its tuned
Shorter dog bones
E3 Diamond Fire spark plugs
Red ZZP spark plug wires
Comp cams custom pushrods
Airaid Throttle body spacer
MSD Blaster coil packs
Comp Cams Hydraulic Lifters
High Velocity Throttle Body for the L36
Oversized Aluminum Radiator
Meziere Electric Water Pump
Comp GT1 Cam shaft
1.9 Ratio Aluminum roller rocker package with 105# springs/ retainers
JE forged pistons
ZZP Ported Heads
Cartuning Performance Intercooled Turbo Kit
Variable Boost Controller
Custom gauges, battery level gauge, boost gauge
Im not sure what transmission upgrades im gonna need or even if my little 4 speed will be able to handle it once its upgraded, So any and all comments would be helpful
Shorter dog bones
Comp GT1 Cam shaft
JE forged pistons
ZZP Ported Heads
