Updated: P0455 - EGR Self-Delete?
SlowNA06
Hey fellas. Scanned the '04 GTP tonight:
P0455 Evaporative Emissions System Leak Detected - Gross Leak/No Flow
No visible leaks or disconnections anywhere. Gas cap is in good condition.
So, do I have to replace a part? Take off the EGR and clean it (if so, best method?)?
Anyone have a general troubleshooting guide (checked gpona's manual, recommended some kind of smoke test to start troubleshooting... so I guess that would mean taking it to a dealership)... like a list of likely/cheap replacements or tests?
Thanks in advance!
Edit: Further research seems to indicate that the "evap canister vent solenoid valve" located in the driver's side rear fender gets dirty and can be cleaned by removing the wheel, wheel well, pulling the thing out, and hitting it with compressed air and carp cleaner. At least, I guess this is something that's almost free to try before throwing money at it. GM Part# 25932569 EVAP VALVE... in case I break or just need to replace it after all.
No time to do it until Saturday, so still open to suggestions.
Re: P0455 - EGR Self-Delete?
Thanks in advance!
I was having an problem with my EGR.. But I did what someone told me and all it good currently! I just sprayed the heck outta the EGR with carb cleaner and took a few Q-Tips and cleaned her out and it seemed not to work on the first run, but after a few mins a start and go, it came back to life and works fine for now.
So Clean it with some carb cleaner and grab some Q-tips and a few shop rags and go to town!!!
I've never touched the EGR before - do I need to replace a gasket or anything when I pull it out?
Just depends on if the gasket comes off with the EGR.. Mine didn't, so I just used some high temp rtv stuff and slaped it back on. I did buy a new gasket just in case the old one was shot, but it was just fine!
So go buy a gasket and some high temp rtv, and pull the egr off, if the old gasket stays put, then inspect it for tears or cracks, if you don't see any, you should be good.
The EGR is not part of the evap system. I would take it to a shop and have them hook up a smoke machine to it to find the leak. It will save you days looking and should not cost too much.
Update:
*Fresh spark plugs
*Fresh oil, filter
*Cleaned up around filter area w/simple green
No more code. WTF? None of those things should have fixed it. I'm almost angry that I didn't fix it with anything that makes sense.
