5qts of RP w/ a Wix Oil Filter $35 at O'Riellys
GeddyLee
I went into O'Rielly's today to pick up a wrench and saw they had a coupon for 5 Quarts of Royal Purple plus a Wix Oil Filter for $35 bucks. It's a good deal if you dont feel like having to order it and wait.
Just thought I would pass it along.
I am probably gonna go back for a 2nd kit that way I am covered for a while :)
Too bad I use K&N oil filters. :(
I used K&N filters as well, but after Farnsworth conducted his own little test of various Oil Filters, he said the K&N filters had part of their folds basically smashed on one side, meaning the oil would only pass through half of the filter. Mind you this was a used a oil filter, but he tested several others including the Wix and the AC Delco uses Wix filters rebagded to AC Delco, and he found them to be one of the best looking after use.
So for after switching from Mobil1 filters to K&N for the past couple years, I have decided to give Wix a try. But still at 35 bucks for the oil, you are saving about 6-8 bucks for 5. So it still adds up as money in your pocket. And you can still buy your K&N for a little less due the money you save from the Oil :)
RP 5w-30 is $7.05 a quart in the shoppette on base, no tax. So, you see my dilemma.
After tax, though (since on base doesn't have the HP-2001 K&N filter), it'd be cheaper than having to go buy the K&N and oil. I may give it a shot.
I'd be interested hear Farn's reasoning on why Wix is a good filter. Not saying it isn't, but the gritty is in the details. :th_mischievious:
I had also heard that about the K&N folds being smashed. It's a shame, as the rest of the filter is actually a great design.
I am total agreement with you there! I loved my K&Ns, switched over from my Mobil1 Oil Filters when I switched to the 2001 (the S10 size filter) model K&N to allow me use a full 5qts of oil.
But when Farns told me about his little experiment in cutting them open it really gave me pause. I like the K&N with ease of install and removal via the wrench connection at the bottom of the filter. I wish more companies would do something like that.
Obviously his tests are just visual inspections of used Oil filters and their state after use. It's not like this is sceintific by any means, but it gives a good indication which ones are better and which might not be so good.
I will try and search the KC boards for the link and post it here hopefully :)
The local mom and pop auto parts store, told me the same thing Geddy is saying about WIX. I was in the parts store picking up supplies (eventhough it costs a little more sometimes, I support the real auto parts stores) and we got on to the subject of filters with one of the owners. They do service in the lower level and had a big collection of oil filters that they cut open to look over. The only thing I rememeber was how shocked I was with their findings and that as a result, they switched over and highly recommend Wix.
I'm not going to comment on the quality of other specific brand names related to cars. I do know from my motorcycle days, Fram was considered the devil because there were a few cases where the filter media fell apart and became distributed thoughout the engine. I saw the pictures.:th_lipssealed1: For that reason Fram isn't even an option for me.
fwiw I use either ACDelco or Wix filters and the last case of RP cost me 5.50 per qt. with free shipping from Greg at Pace with my CGP discount.
just an FYI as well...... the Purolator1 oil filters at Advanced auto...are the same as Mobil1 oil filters. they are made by the same company. This also saves you a few bucks...as you are just paying for the name.
someone on one of the boards had a post showing who made what, and there are a total of 2 manufacturers (if memory serves purolator is one of them) fram and wix are the same filter (although wix has 3 different filter classes, the ones at oreilleys are the cheap line, napa has the mid line, and then the racer line)
All these filters are confusing me. What's a good filter that is able to run for 6 months (only about 4k miles)? And the longer filter we use is just a S-10 filter (4.3L)?
Nobody? All this filter bashing and no one has a solid recommendation other than Wix?
Well I'll give you my input and let it be that, cause I really dont want to get into a filter debate.
I hear people all the time say this filter is better than the other, I wouldnt use this one to save my life, etc. When I started venturing into tweaking cars, doing my own maintenance and such I wanted to know why one filter was supposedly better than the other, so I asked the people that made such statements, thinking they would know why. Want to know what the most common response was? Because Ive never had any trouble with it, and its what Ive always used.
Well that obviously is no testament to the filters quality. There are a lot of things in life you can do or use that you may never have any trouble with, it doesnt mean its the best.
So to get to the nitty gritty you have to be able to compare filters apples to apples. To do that you have to know the results of the ISO 4548-12 multi-pass filter efficiency test. That test is done on all filters, but not all publish their results. What you commonly see on the box or advertised is that this filter is 98.7% efficient (known as absolute efficiency in the industry). Well okay, thats wonderful, but they are leaving out critical information. The particle size that that filter is 98.7% efficient. It can be anything because they dont post that information.
That efficiency could be a 10 microns or it could be at 60 microns, you dont know because most wont tell you and without that piece of information, comparing filters together is impossible. What you dont realize, is that they all are tested and that information is known, just not always published.
The construction of a filter is another aspect that you can compare if you are willing to do the work. I service a lot of vehicles and I always cut open the filters to check for any signs of internal engine damage and the construction of some filters is down right scary. But filter failure due to poor construction is not terribly common. You suffer more long term effects from poor filtering ability than construction quality.
So in choosing a filter, find the ones that will give you the efficiency results along WITH the particle size they reach that efficiency at. Otherwise, there is no point to trying to compare them.
Just because one company has one filter that is perceived as being a good one and makes others does not mean they are made to the same standards or to the same filtering ability.
Where would I find that?
That, my friend, is the million dollar question. I know of only two companies that post that information freely.
Motorcraft used to post it, but I checked recently and cannot find the information any longer. To their credit, they used to post it. But the numbers were nothing to write home about. One filter, for example, was only 80% efficient at particles 40 microns and larger. 40 microns!!! Thats friggin boulders inside the clearances of engines. Another thing revealing about their oil filters was that not every filter had the same rating, it was all across the board.
The only other company I am aware of that posts such information is Amsoil and all of their EaO filters are 98.7% efficient at 15 microns and as far as I know, based on the information I can find, is the best filtering ability available. I have not found another filter yet that posts such numbers. Their bypass filters are even more outstanding coming in at 98.7% efficient at 2 microns I believe it is.
With regards to filter construction I will add only this. Its one thing to compare a new filter to a new filter. Its quite another to see how that construction holds up after a few thousand miles.
I'll give you an example. I have a customer that had two vehicles that I serviced and bought a third. He ran an engine cleaner through the new used vehicle per a recommendation from me, for 1500 miles, using an off the shelf filter. He then wanted to me to come an service it from front to rear and service one of his other vehicles that was due having 10,000 miles on the oil change.
I brought my oil filter opener because I knew what to expect and what I would see, but I wanted him to see it to sorta re-enforce the quality of the products he was already using.
I cut open the 1500 mile filter, I dont recall what filter it was. It wasnt a Fram, he is dead set against those for any interval, but it was one of the cheaper brands.
At any rate, we cut open the 1500 mile filter to inspect it to see what the engine cleaner had removed if anything. Well, he was sitting right there with me when I did this and as I began to inspect the pleats, the thing just crumbled apart. Very little pressure caused the pleats to just disintegrate because they had become so stiff. I even gave him the element to see for himself. The drain back valve had lost a great deal of its pliability but probably still worked but I would not have left that filter on the vehicle much longer.
After that, we pulled in his other vehicle that had 10,000 miles on the oil. I proceeded to pull the filter (Amsoil), cut it open. I gave him the element and let him do the inspection. He was able to spread the pleats apart quite a bit to inspect in between them for any signs of trouble and the filter STILL held together. It demonstrated to him what I knew.
So again, comparing the construction of a new filter to a new filter may reveal a few things, but nothing like comparing them after they have been in service for an oil change interval.
