need lighting info asap
onetyme77
:th_scratchhead: i searched the other threads and could not find one that would help me. I need to know how to change my fog light bulbs on a 98 gp gt. plus i have some halo projector headlight, the kind with the 3 l.e.d's in the inside corner. Does any one know if you can replace the led in the halo, mine is out
To get to the fog lights, you can access the driver side by removing the driver side headlight and looking down. You'll see two bolts where the fog light housing mounts. Remove those and you can slide the housing out and replace the bulb.
The passenger side you have to go from the bottom up since the horn is in between the headlight and the bolts.
I think you can replace the LED in the halo.. I lost contact with the place I got them from. One LED in the halo is out in mine too /:
You got yours from Dazh Z Racing
They will Replace your Headlights if they arent working as intended
no i got my from a ebay company called gforce usa, i called them today and fortunately they are still under warranty and they are going to replace them
Thanks I gues ill wait till i get my new headlights since i got take one out, i thought you could get to them from the bottom, thanks tho
