you're looking to get two things done to lower KR:
First is getting cool air efficiently into the engine, whether it be by a less restrictive and well insulated intake, to an intercooler, rockers, cam, etc.
Second is getting the air that you suck into the engine, OUT of the engine. All the above won't help you unless you have a way to expel the hot gases out of the combustion chamber. Believe it or not, you can't always get everything out of the chamber, and some does end up getting left behind.
First and foremost with these engines, you want it in good running condition. Carbon buildup will cause KR, this is because it tends to create inconsistent temperatures on the pistons, valves and such (carbon retains heat). Spark plugs play an important part in this (as Lee and I have gone over this issue time and time and time and time again). I will go as far as to say that just "certain" types of plugs are not good for forced induction engines, as they will also retain heat and remain a hot spot depending on the material they are made of and the shape of the electrode. I will give Lee credit on this issue, as he has somewhat disproved certain platinum/iridium plugs.
I guess what I'm saying is, be prepared ahead of time for what you plan on doing, and then go a step further. If it's running like poo now, then it's not going to be in the best performance condition later.
