o2 sensor
Vlad0691
I have an 04 grand prix gt. I am installing my SD headers, and I'm wondering if I need o2 sensor extensions? I'd rather not need them, but it is what it is. Can anyone tell me if I need them or no?
no.
splice wire in on the vehicle side of the O2 sensor harness.
Make sure you use non insulated crimping butt connectors, solder then shrink wrap and electrical tape....
Only one thing beats that: running a whole new wire.
I don't know anything about wiring... damn it lol.
What do you mean by vehicle side o2 harness?
I'm a noob lawl.
Don't modify the O2 sensor itself.
Only modify your vehicles O2 sensor wiring or buy the extension from say ZZP.
I extended the sensor wiring itself, and it worked out just fine. Just make sure you solder the connections, heatshrink it, and then wrap electrical tape around the whole deal like matt said.
I have the SD headers. you need an extension for the front, I bought them from ZZP, because, although I know "some" about wiring, there was a massive debate about whether you could safely, and properly, splice in wires and make it longer. I just played it safe. I dont have a CAT anymore, I connceted two spark plug non-foulers (10$ from Napa) and put the rear O2 back on. $5 o2 cheater/non fouler how-to - evolutionm.net
or buy the emulater. your choice. My car ran like **** without the rear O2 in
^^ the pcm doesnt use anything from the secondary o2 for engine managment, so your car runs the same with or without it. just turns on the SES light. but in a few of the 04+ ive seen (mine included)they run fine with the rear o2 and no cat. but if u dont know what ur doing spend the 15 bucks and buy em
not true. tell that to a ton of 01+ guys that can't stop their car from running pig rich without a rear o2 sensor.
must be something with the 7th gens then, cuz i know when mine was out waiting for my extensions it ran fine. as did several other 8th gens i know of.
