02 Headlight Assembly Problem
RichardL12
I changed my headlights the other day and I noticed that the driverside headlight sat higher than the passenger side (large gap between bumper and headlight assembly). I figured I would just try to fix it once I changed the bulb but when I put it back on the assembly still say higher than it should. Does anyone know why or how to fix it?
I had the same problem when I just took my assembly out to inspect them.All I would say is to play with them a little,adjust and what not and eventully you should have even height assemblys.
I messed with it for a loooooooooooooooong time and it wouldn't go in right, I got the passanger side in 5 different times but did not get the driver side once
Thats funny because my driver side was higher too lol.And after closely inspecting it still isd slightly higher but not enough to notice.Try and get them as close as possible unless you're anal lol
i got the same problem! so used some rings and put them between the car chassi and the screw and fixed my problem
thats still pretty quick.You must launch real good.I put 15.7 stock and although I have an intake,180 thermo,and high flow cat I dont think im low 15 and im on sea level lol.
