What size is the fuel pressure test port?
How about this are the threads 7/16"? I called someone about the -4AN and they pointed me to a fitting and the threads are 7/16" because it fits some GM models. Sounds like it could thread on but i dont know if it will seal.
How about this are the threads 7/16"? I called someone about the -4AN and they pointed me to a fitting and the threads are 7/16". Sounds like it could thread on but i dont know if it will seal.
You will be running a risk of the fitting leaking. This is really something that you don't want to cheap out on. If you do a search for Russel fittings, you can get them from Jegs...they are the only ones that I recommend.
